Turbo O-ring?
Old Jul 17, 2006 | 02:08 AM
swede850T's Avatar
Default Turbo O-ring?
Good day, forum folks!
Been a while since I've posted, which means all has been well for a while with my 94 850 turbo wagon. I've since passed the 200k and am approching 210k. During the last oil change it was noticed that there is oil leaking out of the turbo. I seem to remember a post about an o-ring that is not too bad to replace. Any one have a link or hints on that?
Thanks!
Old Jul 17, 2006 | 09:16 AM
S70driver's Avatar
Default RE: Turbo O-ring?
RMS (Rear Main Seal), this could be your problem.
Old Jul 18, 2006 | 12:11 AM
If the block is wet where the pipe goes from the turbo to the Block then the o-ring is bad.
The turbo's are known to leak a little oil where the induction hose goes on the turbo.
Old Jul 26, 2006 | 01:51 PM
swede850T's Avatar
I'll double check on the block -- if it's in fact the o-ring, how hard is that to change?
Thanks!
Old Jul 26, 2006 | 08:50 PM
It will take you about 15-20 minutes.
tech
Jul 31, 2020 09:15 AM
pierremcalpine
Nov 10, 2014 05:23 AM
trooperone
May 29, 2010 11:08 PM
flatspin911
Feb 20, 2010 06:19 PM
dcarlson12
Oct 27, 2008 12:18 PM
