turbo power indicator arrow on the dashboard
Old Mar 9, 2009 | 03:30 AM
jikispqr's Avatar
Default turbo power indicator arrow on the dashboard
It is second day, my turbo power indicator arrow on the dashboard is standing in the middle, as if the engine is turned off.
Turbo is working, but the indicator is failing to move, what might be the cause of the stucked arrow?
Thanks
Old Mar 9, 2009 | 12:49 PM
villagepc's Avatar
it could be a gauge failure.
it could be the vacuum line from the engine bay to the back of the boost gauge came off.
it could be a hole in the vacuum line from the engine bay to the boost gauge.
You'll have to remove the dash cover to access the back of the intstrument cluster to verify that the line is still attached.. you should be able to test it once it's accessible with a piece of vacuum line and few pounds of suck.
if the gauge works, then its in the engine bay or the line.
whichever it may be, it might be a good idea to install an aftermarket boost gauge now so you can have accurate boost readings...
Old Mar 9, 2009 | 07:17 PM
There is a t under the dash you can check.
Also under the hood there is a white plastic hose or black hose that feeds the turbo gauge check it as well.
Old Mar 25, 2009 | 04:21 AM
jikispqr's Avatar
after the gauge went off, now i am having problems with turbo itself.
when boosting, the turbo fails, or the automatic gear box is failing to respond to the turbo boost.
i don't know what to blame.
yesterday i had the car to check the elignment, and there was oil leek from one of the hoes underneath the engine.
Old Mar 25, 2009 | 06:35 PM
Do you get a good amount of boost then it stops?
Old Mar 27, 2009 | 03:09 AM
jikispqr's Avatar
no, it is not boosting, kind of the automatic gear box is stuck.
Old Mar 27, 2009 | 07:12 PM
If it is not boosting then the turbo is not working for some reason.
Old Mar 30, 2009 | 09:53 AM
jikispqr's Avatar
today i checked my car on computer,
computer found 1 fault in automatic transmission;
and 5 faults in engine all deriving from problems in the third piston. i don't know what kind of problems are these - could it be the spark plugs or spark wires?
Old Mar 30, 2009 | 07:57 PM
It could be possible.
PhilG
Aug 29, 2010 11:58 AM
dman777
Aug 12, 2010 08:58 AM
geo81mm
Jan 7, 2008 06:24 PM
maron96
Apr 28, 2006 12:13 AM
phbreuer
Jul 5, 2004 05:18 PM
