Dashboard light indicator won't go out
Old Aug 11, 2010 | 06:44 PM
dman777's Avatar
Default Dashboard light indicator won't go out
on my 1990 Volvo DL, I recently got rear ended with my back smashed up. One of the taillights was smashed which caused the dashboard light to come on e that indicates there is a light out somewhere. I got it fixed at a body shop and bought brand new tail lights. The tail lights work perfect, but the dashboard light still comes on when I brake(to indicate a bulb is out). However, I checked all the bulbs and they all work. Any suggestions?
Old Aug 11, 2010 | 08:36 PM
tedv's Avatar
All the corresponding bulbs should match... make sure they are all the same, that sensor is really sensitive to voltage discrepancies.
Old Aug 11, 2010 | 10:18 PM
swiftjustice44's Avatar
+1!!!!!! When the bulb out relays first came out, they were even pickier! When one bulb burned out, it was often necessary to replace all the bulbs on the circuit...occasionally it was necessary to match the brand! So...make sure they used an 1157 rather than a newer bulb and consider swapping the other brake light bulb(s).
Old Aug 12, 2010 | 08:12 AM
wojeepster's Avatar
as has already been said replace in pairs and don't forget to check the high brake light in the middle
Old Aug 12, 2010 | 08:58 AM
dman777's Avatar
I did replace in pairs...both tail lights are new. Strange, on the way home from work this morning the light didn't come on in the dashboard. So I hope the problem disappeared and won't come back.
volvoralph
Jul 19, 2016 04:19 PM
weston97glt
Jun 25, 2009 06:49 PM
jikispqr
Mar 30, 2009 07:57 PM
orcutd
Sep 27, 2008 08:13 PM
poorman
Jan 21, 2006 04:28 AM
