turn over problems
Old Mar 4, 2008 | 10:34 AM
fattyblow's Avatar
Default turn over problems
When ever my battery is connected it seems that my car want to turn over by itself without the key in the ingition.I took it to the dealership and they said it needs anew starter but I just put one on not even a month ago. What could it be.(Does anyone have the wiring connetion setup for the starter)
Old Mar 4, 2008 | 01:56 PM
sasp11's Avatar
Default RE: turn over problems
It sounds like a bad starter. When the new starter was installed a month ago was it working properly?
Old Mar 4, 2008 | 03:42 PM
Ozark Lee's Avatar
Here is the schematic for you.
Edit - I tried but I cannot get the picture to post.
...Lee
Old Mar 4, 2008 | 06:06 PM
Volgrrr's Avatar
ORIGINAL: fattyblow
It sounds like thestarteris permanently energised somehow or other.
Basically the starter motorcan only be energised by the solenoid contacts which close after the solenoid yoke has meshedthe bendix drive withthe flywheelring gear.At this point the starter is motionless.
After the bendix drive is firmly engagedin the ring gear, a set of contacts within the solenoid areclosedand these contacts thenconnect a supply direct from the battery toenergise the starter motor whichimmediately spins,cranking the engine.
There are only three components that can interupt thesupply to the starter solenoid and they arethe (1)ignition switch and (2) transmission starter inhibitor switch and (3) alarm relay, and Ithink it would be highly unlikelyany of theseitems would be the cause ofyour problem.
I'd suggest you disconnect thesolenoid supplywirefrom the solenoid (small wire - top terminal, the other rerminal will have a heavy battery wire connected to it) and, if the starter motor then still continues to rotate, I would suggestthe solenoid contacts arefaulty (welded contacts???) asthe starter motor is then being fed through the closed solenoid contacts which,with the solenoid itself de-energised, should be open.
If you feel this is beyond your ability, then I'm sure it wouldn't take a competent, proficient autoelectrician too long tolocate and rectify the problems with your starter motor.
Best of luck.
Old Mar 5, 2008 | 01:49 AM
fattyblow's Avatar
Yeah it ran okay for maybe a week
Old Mar 5, 2008 | 08:30 AM
Psaboic's Avatar
Yep, most probable is a bad starter. If you swap out starters and it still does it then, the only other thing I could think of is somehow there may be a short in the wiring that is constantly send voltage to the starter.
Old Mar 5, 2008 | 06:21 PM
fattyblow's Avatar
What does it mean if you go to start the car and the connector from the solenoid to the starter motor starts to smoke and or burns up
Old Mar 5, 2008 | 07:15 PM
Usually the starter soleniod got stuck on. and kept it spinning.
Old Mar 6, 2008 | 08:30 AM
Psaboic's Avatar
As tech said, the starter solenoid is most likely stuck causing the starter to draw a LOT of battery juice. I would swap out the stater and see what happens
Old Mar 6, 2008 | 10:23 AM
fattyblow's Avatar
Thanks for the help but come to find out the power wire that were connected to the post were touching the solenoid outpost sending constant power to the starter.
PinnacleWax
Mar 12, 2014 04:18 PM
Brian Wilson
Apr 1, 2013 08:57 AM
Volvo240guy
Jul 7, 2007 12:12 AM
pmb
Sep 13, 2006 12:15 AM
phil22
Nov 16, 2004 12:14 AM
