Turn Signals / Brights / Hazards don't work
Old May 12, 2011 | 11:50 PM
eplanajr's Avatar
Default Turn Signals / Brights / Hazards don't work
So today my wife calls me and says she smelled something burnt from her dash, its a 97 850. Well now her turn signals, hazards and brights don't work. I figured it was a flasher or relay, so I went to the auto parts store and picked one up. It's a three prong relay...
I spent an hour trying to find the relay under the dash to no avail. When I pulled the hazard switch out I noticed its way longer. I did a search and can't find any definitive information.
Did I get the right thing? Pic is below. One the right is what I bought, the one on the left is what I pulled...
Old May 13, 2011 | 12:00 AM
gdog's Avatar
Um, did you ck the fuse?
And no, those two things in the pic are not the same. The flasher switch (item on left) is common failure point too; is that where the magic smoke leaked from (i.e. does it smell burnt)?
Old May 13, 2011 | 10:36 AM
eplanajr's Avatar
I can't seem where to find the relay goes.
The hazard switch doesn't have a strong smell of burnt-ness.
I checked the fuses and they are are fine.
Old May 13, 2011 | 03:23 PM
eplanajr's Avatar
I just rechecked the fuses. Hazard buse was blown. Put a new one in and everything was groovyfor like five minutes. Now it blows the fuse everytime I insert a new one. It is fuse 13.
Old May 13, 2011 | 05:30 PM
eplanajr's Avatar
Default update
-I took apart the steering wheel and took the turn signal arm stalk out and made sure all the connections were good. I put it back together.
-Voltage at the fuse looks ok, put a new fuse in.
-Doesn't pop
-Turn signals and hazards working again.
-Then a tiny bit of smoke coming from the harness that runs parallel to the steering column. Wires aren't hot nor can I find any bare wire anywhere.
Super wierd.
Old Aug 19, 2013 | 01:30 AM
eplanajr's Avatar
Bump to the top.
Old Aug 19, 2013 | 06:20 AM
Brick850's Avatar
Have you been having this problem for 2 years?
Old Aug 19, 2013 | 02:08 PM
eplanajr's Avatar
LOL... kinda
When I first had the problem I took off the knee bolsters to diagnose and see if I could find anything in the area metallic touching the wiring harness or anything. The problem had gone away for a long time because I never put the bolsters back in. A little while back I put the bolsters back in, and the problem came back. At the time I wasn't thinking about that being an issue. Today I was looking around at it and saw that there is a wire touching the metallic bolster, it was shorting to the bolster.
Problem found/solved (question mark/period)
Old Aug 20, 2013 | 11:02 PM
It's nice to know there are other procrastinators out there and I'm not alone.
hobbitwho
Nov 20, 2010 01:59 PM
enoble
May 29, 2010 03:51 AM
Magnet
Dec 8, 2008 12:06 PM
BuildinAs70
Jan 1, 2008 08:56 PM
rj0828
Jun 14, 2007 03:06 PM
