turn signals and hazards dont blink
Old Dec 31, 2007 | 10:21 AM
BuildinAs70's Avatar
Default turn signals and hazards dont blink
hows it goin guys, well when i go to take a turn and hit the signal it just lights up, no blink, and hazards dont work at all, for the first day i owned the car they worked fine, and every now and then they will work. any idea?
Old Dec 31, 2007 | 11:20 AM
JimKW's Avatar
Default RE: turn signals and hazards dont blink
In older cars they had a blinker box. I'm not sure if the Volvo's have one or not, but what you are experiencing is exactly what would happen when the blinker went bad. Do you have the Owner's manual. I'm fairly certain there is a relay for this based on looking at the 850 Haynes manual, but I could not tell where it is.
Old Dec 31, 2007 | 05:12 PM
Usually it is the hazard switch that is bad when it happens.
The switch is also the relay.
Old Jan 1, 2008 | 06:50 PM
alright, ill check the switch out, it lights up but when i push it nothing happens. will it be obvious that the switch went bad or will i just have to replace it and find out?
Old Jan 1, 2008 | 08:23 PM
Usually you have to replace it.
Some times pushing it in and out multiple times fast will make it work for a little while.
Old Jan 1, 2008 | 08:56 PM
alright, thanks. ill see what i can do
csangree
Jan 8, 2015 10:02 AM
eplanajr
Aug 20, 2013 11:02 PM
Ramin182
Feb 28, 2011 07:13 PM
hobbitwho
Nov 20, 2010 01:59 PM
Magnet
Dec 8, 2008 12:06 PM
