no turn signals and no Hazards
Old Dec 18, 2007 | 08:46 PM
Magnet's Avatar
Default no turn signals and no Hazards
Hi,
I have a 98 S70 GLT. Earlier today my turn signals and hazards stopped working? Also, Fuse # 13 is blown.
Is it the hazard switch that needs replacing? If so, what part number is it and is a diagram available?
If not the hazard switch, what else could it be?
Thanks in advance,
Darcy
Old Dec 18, 2007 | 09:48 PM
Default RE: no turn signals and no Hazards
The hazard switch is the system relay.
It might be that or something wrong with the wiring to the lights.
Old Dec 18, 2007 | 09:50 PM
Magnet's Avatar
So, if the hazard is the system relay, would that also be the cause as to why my radio isn't working either...
Old Dec 18, 2007 | 09:56 PM
No the hazard switch is the turn signal relay.
That radio is seperate.
Does the radio light up at all?
Does it say code? (If so then you need to get the code from the Dealer)
Does the radio say OFF? (If so then you need to leave the key in position I for 2-3 hours to reset the radio) Then enter the proper code for it to work.
Old Dec 18, 2007 | 10:44 PM
Magnet's Avatar
The deck (radio) is an aftermarket. Yes, there is power to the deck because it lights up, but has no functionality.
Is there an procedure available for installing the hazard switch? Anything to consider before installing the Hazard switch?
Thanks,
Darcy
Old Dec 19, 2007 | 05:37 PM
The hazard switch just pops out of the dash.
Old Dec 8, 2008 | 08:52 AM
jreisner2's Avatar
Darcy, I have exactly the same problems with my '96 850 Turbo. Did you ever fix them? How? Thanks for the help.
Old Dec 8, 2008 | 12:06 PM
elmo_allen's Avatar
I had the same problem with my S80 (wipers, turn signals, high beams, parking lights and controls on the steering wheel did not work) and this is what worked for me. This might sound crazy but, I'd look at the fuses for the turn signal and the high beams and replace them with new ones even if the ones that are in there are good.
Here read this... I know it is for an S80 but this might help you out because this is where I got this crazy idea. LOL
http://wiki.answers.com/Q/What_is_wr...e_is_not_blown
eplanajr
Aug 20, 2013 11:02 PM
volvo s40 1.9
Jun 2, 2011 11:13 AM
hobbitwho
Nov 20, 2010 01:59 PM
enoble
May 29, 2010 03:51 AM
BuildinAs70
Jan 1, 2008 08:56 PM
