typical warm up period
Old Jul 10, 2006 | 09:49 AM
cuba's Avatar
Default typical warm up period
I'm pretty sure the stat has failed open in my 94 850gle.
I have bought a replacement stat. Will fit it tomorrow.
The reason I believe it's failed, is quite a long warm up. Although the engine will reach running temp (3 O'clock position), it is only after what I would consider, a longer than usual period of time. Morning temperatures are 0-5 celsius (32-41 degree Fahrenheit).
Can anyone tell me what a typical warm up to running temp would take?
Although I consider the stat to be faulty, I still find myself second guessing.
Any input would be appreciated.
Old Jul 10, 2006 | 03:24 PM
billofdurham's Avatar
Default RE: typical warm up period
I usually hit normal running temperature, in the conditions you describe, after 5 minutes or so. The heater is starting to blow warmish air after about 1 mile.
Old Jul 10, 2006 | 09:05 PM
cuba's Avatar
Well here is the culprit. The retainer has broken away from it's tabs, therefore failing open.
http://img.photobucket.com/albums/v3...s/IMG_3304.jpg
Squirt
Dec 29, 2020 02:53 PM
Vineboydownunder
Mar 29, 2009 08:52 PM
C70CoupeMaui
Feb 24, 2008 08:43 PM
shimby
Jan 4, 2008 10:50 AM
sdat1333
Jun 14, 2007 07:27 PM
