upgrading 850 ECU
Old Jun 26, 2006 | 06:07 AM
pvolvoman's Avatar
Default upgrading 850 ECU
i have an 1996 volvo 850 turbo with just under 100k miles. I understand that there are IPD, upsolute, vp tuning, heico, tme, etc etc chips. They cost in the ranges of 350-750 or so. I have wanted to get a chip, but am hesitant in doing so because from what i hear, i should think about my gaskets. I understand that upgrading your ECU makes alot of strain on an engine, especially 10 years old. If i were to get a chip, should i think of re-doing a bunch of gaskets??? should i NOT worry?? and if I were to re-do gaskets, which ones are suggested, or known to go with a chip, what should i be looking of spending before the chip?? if someone could give me a heads up on whats best for this situation, that would be great. Being very detailed is not a bad thing, please tell me whats up with an ECU upgrade thanks- pete
Old Jun 26, 2006 | 10:55 AM
S70driver's Avatar
Default RE: upgrading 850 ECU
First off, become a member of VOLVOSPEED. While a member there before asking anything, SEARCH. Look up what STAGE 0 is. It is helpful maintainence items and such. It is in the PERFORMANCE section in one of the PINNED threads.
DO STAGE 0 BEFORE ANYTHING ELSE.
Also do you plan on doing any other mods other then an ECU upgrade? If so you might want to do them before an ECU upgrade. Just a thought.
Chips available that I know of are as follows... IPD (TME), RICA, EST, Upsolute, SpeedTuning USA.
IPD (TME), RICA are the most exspensive but are the best.
EST is the next exspensive
Upsolute follows
SpeedTuning USA is the cheapest.
I have the ST USA upgrade and I love it a lot!
Old Jun 26, 2006 | 01:38 PM
robert213's Avatar
My car has upgraded ECU from IPD USA -- Love It!!
Replace Thermostat with Wahler 87C/190F (NOT Volvo 90C/195F)
https://volvoforums.com/m_16392/tm.htm
Replace ATF
https://volvoforums.com/m_25657/tm.htm
Replace Brake Pads and Rotors
Replace exhaust with downpipe, wideband O2 sensor, Magnaflow cat and Dynomax muffler
Replace PCV/Oil Seperator Hoses
Replace intercooler Hoses with SAMCO
http://www.vivaperformance.com/catal...roducts_id=135
Stage 0
http://volvospeed.com/vs_forum/index.php?showtopic=7281
r213faq
makaveli2k
Aug 8, 2012 12:32 PM
matt01
Jul 23, 2012 11:12 AM
91shelby
Jun 20, 2011 06:56 PM
summit
Apr 24, 2009 10:03 PM
bigern45
Aug 5, 2008 08:14 AM
