Vacuum line for boost gauge
Old Sep 23, 2009 | 02:31 PM
nebsch's Avatar
Default Vacuum line for boost gauge
I am installing a boost gauge and have read that there is a vacuum tree under the throttle shroud in 98 and newer models with extra lines where I can plug in the vacuum line so I don't have to use the T fitting. Will I find this in my '97 850 T5?
Old Sep 23, 2009 | 03:18 PM
gilber33's Avatar
Yes, all 850's have that vacuum tree.
Old Sep 23, 2009 | 03:40 PM
Somthngfrce's Avatar
+1 on that. That's where I tapped my boost gauge. If your T5 has a factory gauge on the dash, then it might be easier to tap onto the vaccum line under the dash, it's less work.
Old Sep 23, 2009 | 04:46 PM
nebsch's Avatar
Somthngfrce. I like the sound of that. How do I find it?
Old Sep 23, 2009 | 04:53 PM
gilber33's Avatar
It's a hard plastic black line. Shouldn't be hard to find. What I would do is just disconnect the boost gauge from the cluster since your installing your own gauge.
Old Sep 23, 2009 | 04:57 PM
Look under the dashboard. Take the cover under the footwell out and look for the vaccum line. take a T and tag on to that line!
Old Sep 23, 2009 | 06:33 PM
nebsch's Avatar
That was very easy! Thanks guys, however, based on the description of a hard plastic black line I almost cut the throttle cable that was nearby. Good thing I followed it first.
Now if anyone has a similarly quick fix for the dashboard dimmer switch I'd love to hear it.
Old Sep 23, 2009 | 07:30 PM
Try to find a used or new switch. They commonly go bad.
Old Sep 23, 2009 | 07:31 PM
nebsch's Avatar
Sorry Tech, I wasn't clear. I'm plugging in the power line for my boost gauge backlight.
Old Sep 23, 2009 | 08:04 PM
Oh ok I think it is a white wire at the headlight switch. I connected mine a year ago.
tyler850t
Apr 5, 2015 01:59 PM
ibified
May 26, 2011 01:03 AM
turbo940v
Sep 3, 2010 08:36 AM
ENDEE666
Nov 23, 2006 10:10 PM
