vacuum lines stumped
Old Mar 28, 2009 | 04:33 PM
j_h_buckley's Avatar
Default vacuum lines stumped
I need the vacuum manifold or switch that is attached to the air filter box. There are 3 lines on one side and a plug on the other. I don't know what it is called or where to get one. I broke one of the nipples off trying to change the line that goes from there to the turbo. I am also curious if my turbo needs to be rebuilt. I have replaced the pcv system. There is quite bit of residual oil in the air lines. It appears oil is leaking on the left side of the turbo. Left (towards the drivers side) of the cool side of the fins. It is dry where the oil lines are. Oil was in that vacuum line that I was replacing. Its a 1997 850 glt around 100k spedometer says 87k.
Old Mar 28, 2009 | 05:04 PM
1271630 is the volvo part#.
I checked FCP groton but they do not carry it that I can find.
Ipd sells heavy duty ones for the 98 and newer cars.
Old Mar 28, 2009 | 08:00 PM
I looked on ipd website to try to get a name for the part. Couldn't find the part their. looked under c70 1998-05. Unless its the turbo control valve.
Old Mar 28, 2009 | 09:17 PM
Yes it is the turbo control valve.
Volvo calls it a pressure regulator.
Old Mar 28, 2009 | 09:43 PM
what do you think about the oil leak and oil in the lines?
Old Mar 28, 2009 | 09:46 PM
That could have been from before you did the vent system service.
If something was clogged it will basically pump oil into the system.
GmacA3
Oct 10, 2009 02:20 PM
1996850turbo
Oct 1, 2008 10:14 AM
goober4321
Aug 29, 2008 06:31 PM
jmana
Sep 8, 2007 04:13 PM
reynrog
Jan 7, 2006 12:36 PM
