Vibration at 70-80km
Old Dec 18, 2004 | 10:39 PM
Macgregorguy's Avatar
Default Vibration at 70-80km
I have a 1996 850CD with 136 000km. It's gets a vibration at around 70-80km. Not all the time. I have had a wheel allignment and wheel balance done, and it's still the same. Any idea's?
Old Dec 19, 2004 | 02:43 AM
Default RE: Vibration at 70-80km
Check all the bushings in the front end of the car
Old Dec 19, 2004 | 02:45 PM
knight rider's Avatar
I also have that vibration at 55-65 mph. I was told it could be ball joints, and mine were F'd, but replacing them also didn't fix it. I tried rotating tires, and still there. Which bushings would cause road vibration? control arm, sway bar, etc. ?
Old Dec 19, 2004 | 03:48 PM
Check all the control arm bushings.Also could be a bad axle.I have seen bad axles cause a vibration before.You can check the axles with the car jacked up.Hold the inner joint and rotate the tire back and forth like foward and reverse with your hand .See if you can feel any play.I have also seen a bad transmission cause a vibration as well.
ocean238
Apr 17, 2008 06:20 PM
JimKW
Jun 14, 2005 06:38 PM
CFGVolvo850
May 18, 2005 10:59 AM
panopticon
Apr 20, 2005 02:11 AM
alecw81
Mar 7, 2005 10:47 PM
