vibration/stuttering when shutting off car
hey guys this one is becoming more apparent when today...i thought i kept screwing up and pulling e-brake first before putting into park and thats why it vibrated (never had that happen to me before) but now even if I don't put on ebrake or shift into park first before pulling ebrake the car rumbles...I don't know why?
Anyone got ideas? The haynes troubleshooting got nothing so far...
hmmmm, thats odd. i know mine is basicly just like when you turn off the car there is a little rummble when it comes down in RPM's to 0 rpm.
on the upper mount wiggle and move around that black support member. you should beable to tell that way. if not rev the motor a little and see if there is movment in it. (rock front to back movment)
Its not the matter of just reving it, you have jerk it push and leave and then see the movent of the engine. It will do that while catching the RPMs or going down the RPMs.
Try asking someone to turn the engine off while you are watching the engine running under he hood and see if you can find the source of noise/rumble.
i dun have the jacks to get under the car...i dun know man it happened again today >< i will give the first idea a go on thursday if i can find sum1 who can watch the car...but it was more frequent this time...GUNG GUNG....GUNG GUNG...GUNG
it comes and goes so it not consistent...normally only when i park in my garage...but once at a parking lot so far
a user on the matthewvolvosite who writes up alot of the DIY repairs...I do have the ABS light coming on but I don't have the TRACS light or the other symptoms that other users have. Or the light could have burnt out...but i dun think so?
http://www.matthewsvolvosite.com/for...p=89134#p89134
He also said that it would kill my speedometer
#18
thanks for your offer but i need the car everyday...i think i should be able to do it myself i am just worried about making mistakes taking it apart...and is there any specific type of solder i am suppose to use? I was told you need a strong one because the pins are quite resilient?
Also the car did it again...the battery was the only light on...also I don't think I have tracs. When i turned on the car(not ignited) only 3/5 of the lights lit up so I am not sure is it burnt out. The ABS light is on more often now so I suppose the ABS is really out? Is there a way for me to test the ABS?
MNWILD
01-26-2011 09:02 PM
