Volvo 740 GL Pump Runs After Shutting The Car Off!
Old Jan 16, 2011 | 01:05 PM
MNWILD's Avatar
Default Volvo 740 GL Pump Runs After Shutting The Car Off!
I can still hear my fuel pump running after my car is shut off. It doesn't do it all the time. Some times the car won't start if i shut it off & then try to restart it after it's warmed up. I'm hoping it's just the fuel pump relay! Any ideas?
Thanks,
Scott
Old Jan 16, 2011 | 01:29 PM
jagtoes's Avatar
Thanks,
Scott
What year is this. Also what pump is running , the main or the tank.
Old Jan 16, 2011 | 09:58 PM
swiftjustice44's Avatar
Doesn't matter and doesn't matter...Most likely it is the fuel pump relay. If the relay points stick closed, the pumps will continue to run. Not restarting hot is quite often the fpr too. There's a chance your ignition switch has worn enough to not always turn off or on completely too. Those are the common issues...there are any number of much less common issues that could cause it. The 6 connector socket that the relay plugs into has an always hot leg on it...even with the key off...that's how stuck contacts can cause the running.
Old Jan 17, 2011 | 08:42 AM
MNWILD's Avatar
Thank you so much guys! I was thinking the same thing on the lines of a fuel pump relay.
Old Jan 26, 2011 | 11:03 AM
scorpius's Avatar
Default fuel relay problem?
I made one of the heated seat buttons a phantom switch for my relay, its the closest to the fuse box and of course you shut it off manually, pretty quick installation, just remember to install a remider light..cuz u might forget to turn it off...lol... thats if u dont wanna buy the whole ignition relay thing...
Old Jan 26, 2011 | 08:02 PM
Trust me, sooner or later, you'll forget! The car will be deader than a Jimmy Carter speech!
urdrwho
Jun 26, 2014 06:39 AM
tjanae80
Oct 20, 2010 10:55 AM
Arsenal6
Jun 8, 2009 09:15 PM
bigblock466
Jul 15, 2008 08:12 AM
robzlrclub93
Aug 16, 2005 03:25 PM
