VIN: emissions number "1"??
I've been digging through everything but I can't find a specification for the 8th digit being "1". On top of that, every time I go to volvocars.com, it times out. Does anyone know what my car has? It's a 95 850 Turbo
The website is down.
Somethings up with the forums vin decoder as well. It gives me a content encoding error. This really sucks.
The 8th digit is not a 0, 2, or 6. It's a 1. That isn't listed there. Thanks, but it's of no help with my case.
on the V40 Volvo's the 1 = KOD:EMH1
Tried out all the models with emission clasifications and the 40 series is the only one with a 1 classification. |
Volvocars.com has a digit 1 for the 850 there but I can't remember what it is. I THINK it's EGR only but I cant be certain.
Your Engine code should be 55 or 57. The latter is FWD turbo.
A 58 is for a T5-R turbo [1992-Present] Emission Control Equipment
If your a 55 its the one highlighted Theoretically?? |
My engine code is 57. It's not listed there. It's a little irritating that I can't get anything to work when I need it. Just my luck.
Found the answer for you finally on Matthews Volvo site.
http://www.matthewsvolvosite.com/vol...6-example.html Harder to read than other forms of VIN description but it has yours on it. Read the 2nd table down the page for emissions info. |
Well, volvocars is back up and I found the vin decoder. Turns out that this is what I have. "1 = w/ EGR w/o air pump, w/OBDII, w/elec. control evap." What should I do about the egr since I'm converting to the NA throttle body? I don't want to deal with the CEL. Oh, another thing is that I have hit fuel cut at least 5 times since my last CEL and I have yet to see a code for the boost controller. It's only ever tripped once.
Yes, that description is the same answer I found on the Mathews Volvo site via the link on my last thread.
Originally Posted by Chrispy_T
(Post 365099)
Only reason to change out the manifold with the N/A TB is to get the bigger opening; most just line bore (or die grind) the turbo manifold to match. Are you going to disable the egr? |
I looked at the EGR and it seemed to be bolted to the TB not the mani, I guess I was wrong. I plan on line boring the turbo manifold and polishing it. I'm also going to tidy up the runners if needed. I want to clean up the manifold as much as possible to smooth things out.
2 Attachment(s)
The throttle body isn't very thick. It's only about an inch and a half thick so the EGR doesn't have room to mate to it.
I think the boss in the picture would be where the EGR bolts up. In the small picture, it's a NA manifold and the EGR isn't drilled open. Found a picture of it !! http://www.tracystruesoaps.com/tutor...o_manifold.jpg |
(Post 365228)
I meant smoothing the surface that I bore out with 1000-1500 grit or so. Not polish the entire manifold. That could be frustrating. :rolleyes: I just want to get the opening as nice as possible.
Don't forget the outside of that manifold :eek:
http://memimage.cardomain.com/member...93_76_full.jpg |
(Post 365259)
I have enough trouble affording function. I'm not anywhere near being able to spend time and money on looks yet either. :D
