Volvo 850 Aftermarket steering wheel
Old Jul 12, 2012 | 12:51 AM
StigAre's Avatar
Default Volvo 850 Aftermarket steering wheel
I want to mount a luisi steering wheel, but I need to trick the srs system that there is an airbag present.
Anybody know how to do this ?
Old Jul 13, 2012 | 10:12 AM
Brick850's Avatar
Wouldn't you rather have the airbag?
Old Mar 7, 2013 | 01:39 AM
angeloprado's Avatar
Any answer to this? I would like to put a different steering wheel on my 98 c70.
Old Mar 7, 2013 | 08:48 AM
1996850turbo's Avatar
Look for how to defeat passenger bag. I assume the resistor needed is the same
Old Mar 7, 2013 | 10:01 AM
boxpin's Avatar
You measure the resistance of the airbag then create a resistor pack of the same.
Old Mar 7, 2013 | 08:27 PM
nitrosport's Avatar
are there any low-cost hub/wheels that fit the 850?
Id like a sport wheel (dont care about having an airbag) but Im used to doing that kinda thing on an old honda civic. Thats easy and can cost as little as $50.
Old Mar 8, 2013 | 02:36 AM
How to measure resistance? What is the tool called? Autozone? Thank you for your responce!
Old Mar 8, 2013 | 03:55 AM
Just pull the bulb. The system doesn't effect the cars drive ability and most states exempt these cars from inspections.
Old Mar 8, 2013 | 08:18 AM
boxpin's Avatar
You Sir, should not be messing with an airbag system until you learn a little more about them and Ohms, Resistance, impedance, etc. That question has hung you out to dry.
Old Mar 8, 2013 | 08:37 AM
ES6T's Avatar
Measuring the resistance of an airbag can set it off, so good luck with that. Airbags are more important than having a "cool" steering wheel in a 15 year old car, in my opinion.
Old Mar 8, 2013 | 03:08 PM
I didn't read through it, 3 pages but maybe something in here would help.
https://volvoforums.com/forum/volvo-...g-wheel-13832/
Old Mar 9, 2013 | 03:37 AM
Boxpin? Im trying to get more knoweledge on this subject. That is the nature of the post. If you arent prepared to be of service, then please stay off my thread. I did not ask, nor would i like your opinion. Please be helpful. thank you kindly sir or mam.
Old Mar 9, 2013 | 04:34 AM
And he is trying to keep you from injuring yourself with an explosive device.
But since Boxpin can't come on your thread I did find that Volvo makes a resistor part #988-8695. Hope that's helpful, don't want to get kicked off too
3) Remove 2 Torx No. 30 screws from rear of steering wheel.
See
Fig. 7
. Pull air bag module away from steering wheel just enough
to disconnect wiring connector. Install SRS (Special Test Resistor)
(988 8695) in place of air bag module to prevent generation of fault
codes. See
Fig. 8
Old Mar 10, 2013 | 12:42 AM
gdog's Avatar
Well you're not going to attain more knowledge by being a arrogant *****..
And last I checked, StigAre started this thread, not you; so technically you're the hijacker.
By all means, please disable your airbag, I like to see Darwinism at work..
ethyre
Jun 20, 2016 12:27 PM
trainlover
Mar 16, 2014 08:48 AM
bond007
Feb 23, 2011 07:56 PM
nehopsa
Jun 24, 2008 11:20 AM
mustafur
Mar 30, 2008 04:19 AM
