Volvo 850 gle wagon engine doesn't start
Old Mar 9, 2020 | 05:09 PM
Pedro Bento de Castro's Avatar
Default Volvo 850 gle wagon engine doesn't start
My 1993 850gle wagon doesn't start. The engine above block has everything new, new sparks, new gasket, and so on.
the petrol is getting to the sparks, the starter works, the engine turns but doesn't start.
help needed urgently, please!
thanks in advice,
Pedro
Old Mar 9, 2020 | 10:50 PM
is there fuel pressure in the rail? pump/relay good? there's also a fuel injector relay on the front by the radiator to check out.
Old Mar 10, 2020 | 03:01 PM
hi,
thanks for your help.
no problems with fuel pressure.
the engine seems to have no pressure although everything is new above block, new sparks.
Old Mar 11, 2020 | 10:14 AM
firebirdparts's Avatar
Well, you need air, fuel, compression, and sparks at the right time. All these are easily tested, and even If you have no fuel, it'll still run on ether. Getting the timing right is not totally trivial of course, but it's also not mysterious.
ashort
Jan 27, 2014 10:44 PM
Mortada.Issa
Engine & Internal
Jun 19, 2011 07:29 AM
brmicbman
Aug 31, 2010 05:09 PM
BERNIE
Aug 15, 2005 06:01 PM
paradigmcubed
Mar 6, 2005 02:58 AM
