Volvo 850 Thermostat and ECT (Engine Coolant Temperature Sensor) Replacement - Video
Old Jun 10, 2013 | 10:10 PM
Lightbulb Volvo 850 Thermostat and ECT (Engine Coolant Temperature Sensor) Replacement - Video
This video will show you how to replace the thermostat and ECT (engine coolant temperature sensor) in a Volvo 850 and some of the S70 & V70's. If your engine temperature is not reaching normal temperature within a few miles of driving you should replace your thermostat.
Some people experience hard and no starts, rough early idle, running rich or lean, etc. when the ECT is bad. It will sometimes cause a check engine light with a P0116 code (or P0123). Sometimes the ECT can cause the motor fan to run for an extended period of time after you shut down the car, which can and will drain your battery.
Old Jun 28, 2013 | 10:33 PM
Stripped housing bolt removal:
91shelby
Feb 15, 2013 03:22 PM
bikeboy1
Nov 26, 2010 07:52 PM
jstarman
Nov 9, 2010 06:32 PM
cisopen
Sep 20, 2010 05:25 PM
