wagon Rear seatback safety latch won't work (to fold it down
Old Jul 9, 2010 | 02:46 AM
850forum's Avatar
Default wagon Rear seatback safety latch won't work (to fold it down
On the topic of bad latches, this has been bad for a while.
The passenger side safety latch that you have to push rearwards before folding down the seat back does not work correctly. Once I needed to do it immediatly, and I got pissed off and used my multi tool saw to cut away the plastic so I could get into the mechanism.
I need to take a screwdriver and use it from the rear as a lever somewhere in there near the base of the vertical bar (the piece that sticks up into the plastic push "button" which has the red indicator that pops up & down). I don't do it often & I always forget exactly how it needs to be done.
Old Jul 9, 2010 | 12:43 PM
vjaneczko's Avatar
hmm, that's a good one.. I'd suggest you take apart the drivers-side for a mirror image. Maybe you could rig a finger-pull or something for the future.
Old Jul 9, 2010 | 02:52 PM
850forum's Avatar
If I could figure out how to take apart the plastic that covers the mechanism, I would. I finally used a saw on the passenger side. But I still cannot see it very well.
Old Jul 26, 2010 | 12:06 PM
Calebz's Avatar
*Subscribes to thread*
My passenger rear seat doesn't unlatch to fold down either.
I am going to either watch this thread for answers or use this thread to provide answers when I find them / figure it out. :lol:
Old May 28, 2011 | 08:03 AM
GreenShenna's Avatar
Came across this thread today because I was obviously having the same problem. I have a 2001 xc70 wagon. My driver's side was folding down fine but the passenger side seat was stuck and the pull lever was not working. As suggested, I tried to take a closer look at how it worked. No luck. However, right under the headrest is a plastic panel that pulls away easily. Viola! Access to a little pull lever. Tried it on the other side with some wiggling and it came free! I hope your models have the same little access panel.
Good Luck!
Eburns666
Aug 4, 2015 10:46 PM
meritage2
Aug 24, 2011 09:52 PM
RackoWacko
Aug 3, 2011 05:44 AM
qstyle
Jul 25, 2010 09:48 AM
850forum
Nov 28, 2005 09:41 PM
