Wanted 1995 850 Diagnostic unit A
Best to get that from a yard. FYI my wire has broken off as well but I am still able to check codes/reset the service indicator. Try holding the broken end in place or use a paper clip to insert into the wire hole and into the wire to connect. Have you tried removing the part to see if you can access the broken wire stub?
mjkoskinen
10-30-2010 03:53 AM
