wanted to say hi...also 95 T5R Qs
Old Sep 15, 2007 | 07:12 PM
wannaseemysocks's Avatar
Default wanted to say hi...also 95 T5R Qs
Hello...Im looking into purchasing a 1995 850 T5-R.
Here are my thoughts...
The car is very very clean! exerior, interior, even under the hood. It drives great and i was surprised by the power it had.
The Bad:
Odometer stopped working at about 124k
supposedly the car now has about 150k
Ignition switch doesnt have a spring in it....you have to start the car then pull he key back...nobig deal to me
The AC doesnt work right now, naturally being in Texas, this is my biggestt concern.
The owner says the AC worked up until a few days ago, she said it jus suddenly stopped. Im thinking its gotta be electrical, maybe an ECM burned out, but i dont know.
What thoughts do you have, the experts, \on this car?
I thank you in advance for any help.
Old Sep 15, 2007 | 07:26 PM
Default RE: watnted to sayt hi...also 95 T5R Qs
Welcome
Normally you would post this in the 850 section.
I will answer since I am here but next time post in the 850 section please.
The gear in the odometer broke. Somewhat easy fix with time.
I made a post about removing the dash pad to gain access to replace bulbs.
Others have also explained how to replace the gear.
Ignition switch is bad and needs to be replaced.
For the A/C it might be low on freon. The 850's have problems with the Evaperators.
Search the forum for more info on your quiestions.
Old Sep 15, 2007 | 07:36 PM
thanks alot tech!!
so do you think the car would be worth buying?
Old Sep 15, 2007 | 08:34 PM
How much do they want?
Old Sep 16, 2007 | 04:17 AM
JPN's Avatar
JPN
This post has been moved from New Member's Forum. Notified the original poster.
JPN
Old Sep 16, 2007 | 08:18 AM
she was asking $4500 before the AC went out...im thinking of offering her $3000 now.
Old Sep 16, 2007 | 08:29 AM
If you can get it for 3k to $3500.00 I would say jump on it.
Maybe even 4k I would jump on it.
Would you be able to do the work your self?
If you have a shop replace the evaperator if it is bad that will be like 1k alone.
But the odometer gear is like a couple hundred for a shop to do.
The ignition switch is like $100.00 or so for a shop.
But you can save a ton if you can do the work your self.
Old Sep 16, 2007 | 08:45 AM
yes i could do the work myself.
Old Sep 16, 2007 | 08:49 AM
Then you will save a ton of Money.
I made a post about doing the Evaperator have you seen it yet?
Old Sep 16, 2007 | 08:58 AM
your talking about the sticky...yes i have read it.
does the evap just go out like that? all of the sudded? it doesnt evewn blow hot air. is that one of the symptons?
Old Sep 16, 2007 | 09:57 AM
No it isn't if it blows no air at all then most likely either the blower motor or resistor is bad.
Also do any of the lights on the panel come on?
Does the little A/C light or recirc light come on?
If not then the A/C panel is bad.(Best to find a used one) New one is like $600.00 if I remember correctly.
Old Sep 16, 2007 | 10:13 AM
JPN's Avatar
JPN
Default RE: wanted to sayt hi...also 95 T5R Qs
Hi,
Just wanted to chip in for 2 popular parts sources:
http://www.fcpgroton.com/volvo.htm#850
http://www.eeuroparts.com/home.aspx
I've used FCP Groton and was happy with their service. Haven't tried Europarts, but seems just as good.
Good luck,
JPN
Old Sep 17, 2007 | 12:32 AM
ORIGINAL: tech
Also do any of the lights on the panel come on? yes
Does the little A/C light or recirc light come on? yes it does...however it flashes on and off
i was thinking somethingh simple like a resistor or a fuse because the owner said it stopped working all of the sudden
Old Sep 17, 2007 | 12:38 AM
RedTurbo850's Avatar
^What do you mean when you say it stopped working?
Not blowing air or not cold?
And if the light is flashing, you need to read the code from teh OBD-I box and find out whats wrong w/ your climate control.
Old Sep 19, 2007 | 12:58 AM
it wasnt blowing air at all
Old Sep 19, 2007 | 07:51 AM
im picking the car up friday! thanks for the help guys!
Old Sep 19, 2007 | 09:13 PM
  #17
JPN's Avatar
JPN
Good luck, let us know how it goes if you would.
JPN
Old Sep 20, 2007 | 12:30 AM
  #18
i certainly will!! first thing will be to get the AC working then some window tint! followed by some new speakers.
Old Sep 22, 2007 | 01:03 PM
  #19
ok...AC questions...
the lights on the unit work...it sounds like the compressor kicks on. but no air. my dad/mechanic thinks it could be the blower motor.
any thoughts from you guys?
Old Sep 22, 2007 | 05:13 PM
  #20
Blower motor or resistor.
