Wastegate mod question 1997 850T5
Old Aug 30, 2008 | 09:58 AM
goober4321's Avatar
Default Wastegate mod question 1997 850T5
I was doing some reading in the wastegate mod by shortening the rod to make more boost. But, I am a little confused on this theory. To make more boost would you not want the wastegate to stay closed longer? So if you lengthen the rod rather than shorten it this would make the wastegate actuate later. Whereas if you shortened the rod it would open up sooner and bleed off pressure and not let you attain desired PSI. AM I correct in this theory? If not someone please explain differently.
Old Aug 30, 2008 | 10:19 AM
S70driver's Avatar
Default RE: Wastegate mod question 1997 850T5
1. Don't do this "MOD".
2. Yes people have done this and had ok results.
3. However this doesn't make it the right thing to do.
4. To make more boost, purchase a MBC at the very least.
5. To do it right get an ECU upgrade. Speedtuning USA $325, Upsolute $425 estimates, it may vary. Or go with a good tuner like IPD USA, RICA.
Old Aug 30, 2008 | 11:06 AM
goober4321's Avatar
Well I was never going to do it but I was wondering if in theory I am correct. If I send my computer to one like IPD for retuning......HOw does this effect emissions testing?
Old Aug 30, 2008 | 11:12 AM
Yes if you were to do it then you would turn it in.
It is a toss up on opinions about doing it. Some people are dead set against doing it. Other people do it and feel a it makes the boost smoother and activate sooner with it closed some.
Some people do it and others refuse to do it.
The chip shouldn't affect the emissions at all.
Old Aug 30, 2008 | 12:59 PM
goober4321's Avatar
But Tech, Would you not want the wastegate to stay closed to build up more boost pressure than open a little sooner to release it?
Old Aug 30, 2008 | 02:24 PM
When you tighten it it does stay closed a hair longer. Also does give a slight more boost. But I wouldn't attempt unless you have a MBC and aftermarket boost guage.
ENDEE666
Jan 29, 2024 01:33 PM
junkycosmos
Dec 14, 2013 01:16 PM
john12345
Nov 6, 2013 05:04 AM
Tripplay81
Jan 4, 2011 03:53 PM
VolvoPower850r
Nov 27, 2009 07:40 PM
