Water pump failure (pic)
Old Nov 11, 2013 | 09:29 AM
Brick850's Avatar
Default Water pump failure (pic)
Hey guys,
Thought I'd share a pic with you. I have recently come back from a 1500mile driving holiday, the car ran great.
I had a stroke of luck though.
Two days before I was due to go, I had installed a N/A throttle body, custom made stainless steel intercooler tubing, replaced the heater core (sweet smell), new expansion tank and changed the coolant.
The day before I am due to go, there is a puddle of coolant next to the right front wheel. "Oh oh" I thought, "I haven't tightened one of the expanion tank hoses properly."
No such luck. Upon removing the timing belt cover, it is weeping out of the water pump.
Poo.
So a new timing belt, new oil seals, waterpump, and accessory serpentine belt gets put on.
Doesn't leak a drop all holiday.
Mechanic says better it happens before the trip, and not in the middle of it. He also says he has never seen a water pump fail like this one did. Most of the time the bearing wears out, or the shaft moves inward and eats into the block.
Mine has moved outward and was eating into it's own housing. It has visible score marks, yet was running silently. I had no idea it was failing apart from the leak after parking it.
It could have been a lot bigger repair bill if I had not caught it in time.
Old Nov 11, 2013 | 10:12 AM
awfulwaffle's Avatar
Yikes, glad it didn't ruin your trip or your car!
Old Nov 11, 2013 | 10:34 PM
What brand was it? Here is a pic of one I had go bad.
Old Nov 13, 2013 | 04:19 AM
Brick850's Avatar
Surprisingly it was genuine Volvo.
Old Nov 13, 2013 | 08:17 AM
Same with mine. Only had 156,000 on it. I had to change one with 86,000 on it, leaking.
I change them if they are 10 years old. To much belt tension on them to long.
Old Nov 13, 2013 | 05:51 PM
Brick850's Avatar
This one had done only 30,000miles according to the receipts I had when I bought the car.
Old Nov 14, 2013 | 08:20 AM
Wow, that is horrible.
Old Aug 6, 2014 | 04:25 PM
taurusxc90's Avatar
Hello, I am new to the fórum and had some problems with my waterpump
Here some info to help other owners
Type of car XC90 2006 motor D5244 diesel 185 HP automatic box
Symptoms: engine temperature normal at idle ,temperature raise and boiling under load,weak cabin heater,upper hose to radiator hot ,lower cold ,cooling fan operates correctly but permanent, thermostat ok, no return flow from radiator in expansion vessel.
Changed thermostat (You need to remove the hydraulic steering pump,leave hoses connected, behind the pump is a hole in the support to acess the lower fixing bolt of the thermostat, Torx 40) Problem was still there.
Removed timing belt and water pump,waterpump shaft was broken at impeller.a new pump and timing belt kit solved the problem.
Jean
Old Aug 7, 2014 | 10:58 AM
Hi Jean, welcome to the forum.
BrwMstrHRx
Apr 12, 2014 10:02 PM
majorcode
Nov 4, 2013 06:41 PM
scrap88
Apr 7, 2010 09:23 PM
katiejoyful
Dec 12, 2007 04:49 PM
ludeless
Jan 23, 2006 10:19 PM
