water in transmission fluid
Old Oct 31, 2009 | 10:07 PM
ukbulldog's Avatar
Default water in transmission fluid
hi folks.
can anyone give any advise on my 1994 850 2ltr auto est, the car will only drive about half a mile before it stops pulling.
i checked the transmission fluid to find it looked very milky. all i can think of is water getting into the gearbox. a friend said the fluid runs into the radiator via cooling pipes and suggests the problem may be in the radiator. not knowing anything about volvo's or auto transmission im none the wiser.
im not sure if the car is worth fixing or not. it sure dont look good thats for sure
i would be greatful for any info.
cheers martin.
Old Oct 31, 2009 | 10:22 PM
The cooler in the radiator might have broke.
But bad news is usually when this happens the coolant destroys the transmission.
Old Oct 31, 2009 | 11:11 PM
ukbulldog's Avatar
yep thats what i was worried about, i did replace the fluid in the transmission straigt away but i fear its too little too late unforunately, suppose i could at least try a relpacement radiator and hope for the best.
thankyou for you speedy reply
Old Oct 31, 2009 | 11:14 PM
Hopefully it works out for you!
s70_007
Dec 19, 2008 09:26 AM
katiejoyful
Dec 12, 2007 04:49 PM
flapper
Oct 22, 2007 05:56 PM
