Weird Central locking Problem
I have an interesting issue; my central locking is playing up.
The car will lock itself ok with the remote but not open. When I push the button it turns on and off the immobilizer. You can see the red light flashing then it turns off. I can however open the car with the key and all the doors open. I have noticed that the fuel flap is not locking/unlocking.
I noticed something strange when driving the car, the light started to illume and then flicker!! Then another time the light turned on and the doors locked and unlocked? Could this be an earthing issue? Or would the stuck solenoid on the fuel flap cause this system to malfunction?
Any help appreciated.
Thanks, it is a 1995 T5R. The remote is working fine. You can see the immobilizer light turn on and off with the remote. I have checked the battery connections they all look good. Where is this module located? You can definitely here a relay clicking when pressing the remote.
Could it be that the fuel flap solenoid being inoperative being part of the fault?
How are you sure that the remote works fine? You said that it locks but do not unlock... I took my remote to the stealer service department yesterday and my remote was only working 50%. The unlock worked but the lock button did not. They can test it at the service department for FREE.
I believe I have a bad remote receiver. I removed mine this morning and tested it as per the ts sheet that I have and it indicated that my receiver had an open short. So I went to my local Volvo grave yard a purchased one today. It is to HOT HERE to do anything outside after 8:00 am so I will install it tomorrow morning before 8.
I have a '95 850 T-5R and the remote receiver is located beside the inside of the glove box. So, you remove the inside of the glove compartment and look to the right and you'll see the receiver, it is a square box about 5" x 4" and 1-1/2" thick that has a green plug going in the bottom of it. Now, my remote system did not work at all, it also did not blink fast when I was trying to program it with the turn the key on 5 times real fast and leave on - then the light on the dash would blink fast for your to click your remote to program it.
Hope this helps.
Hope this helps.
Oh yea, to see if your fuel door lock is working correctly you can open the fuel filler door and lock the car. Then look in the hole to see if the pin is thrown. Then unlock the car and look in the hole to see it the pin has retracted.
My fuel filler door latch was bent back out of the way so it was not locking with the rest of the car. Today I straightened it out and adjusted it so the pin would go through it. Just a simple physical adjustment, bend - twist - pull.
I have seen the latch strip bent purposly on many cars just becuase it gets stuck sometimes if there is any pressure on the pin while in locked position that restricts the pin to retract properly during unlocking. So, make sure when you do the bent-twist-pull activity, the hole and pin are aligned nicely so that you dont end up with empty tank at a gas station. :P
Oh No!!! Big trouble. Ok found the immobiliser, relays 210-211 are missing with a pastic wire arrangement in place. Found 50E and 50F and jumpered (where relay 210 is supposed to be) I done this cause now the car won't start.
Previous to that I think I may have jumpered the wrong place and popped a fuse or two. Found a blown fuse replaced (indicators).
Not sure what to do next, the car will make click noises when you turn the key (relays turning on) I can here the fuel pump going but the starter wont turn. If only I had not started to mess with the immobilser maybe I would have a car that would go. Please help
