Weird fuel pump behaviour 1996 850 10v 2.5
I have been having fuel pump issues recently, that being, my car starts fine the first time every day. I listen for the 3-second fuel pump whirr, start the car, and I can drive around as long as needed. however, once I turn off the car and put the key in the number 2 position, I listen and the fuel pump only runs for about a second. then when I start the car, it dies after idling for about a second and there is no fuel pressure.(checked the schrader valve on the fuel rail). Any time I try to start the car after that, the fuel pump doesn't go on at all, it just cranks and cranks. my battery is good, I have a brand-new pump relay in there too. somebody help! also, I tested the power going to the pump, and it lines up with what I previously mentioned. so I believe the pump itself is fine. what could be causing this mess?
