240 Fuel Pump Not Engaging on Igniton
Old Jan 28, 2019 | 07:09 PM
vinniegnsb's Avatar
Default 240 Fuel Pump Not Engaging on Igniton
I have been having a problem with my 240 rarely starting, due to the fuel pump not coming on after turn key. Sometimes, but very rarely, I will hear the fuel pump whine for a second and then the car will start after I crank. I originally thought I had a defective pump and made the mistake of replacing it, followed by the in-tank fuel pump, and the fuel pump relay. The symptoms really seem to point to the fuel pump relay, but I already replaced it and I have seen no difference in performance. The signs point to something electrical but I have no experience diagnosing something like this. Any help is much appreciated,
Thanks
Old Jan 28, 2019 | 08:33 PM
vinniegnsb's Avatar
Ok so I did a really bad job of documenting my steps but here is an update (it's now working). I removed fuses 4 and 6 relating to the fuel pump and then accessed the fuel pump ground. I unscrewed the ground and did a quick cleaning of the connection, then screwed it back in. I went underneath the car and gave the power connections to the fuel pump a jiggle while I was at it. I tried the ignition on the car again and after multiple times of turning the key the fuel pump finally engaged. I had forgot to put the fuses back in so I did that and decided to try again, and for some reason it just started working. I assume the ground had a problem, even though there were no signs of corrosion or any debris messing up the contacts at all. Hopefully this helps someone else
Old Jan 29, 2019 | 04:43 PM
indeed, the pump only runs for about 1 second when you turn the key on then stops until the engine is cranked over... and when the engine stops turning, about 1 second later, the pump stop.
Catimann
Nov 16, 2016 06:58 PM
Scooter1986
1998-2000 model year V70
Oct 30, 2013 01:21 PM
printmkr
Aug 20, 2009 12:13 PM
volvog
Feb 7, 2008 08:10 PM
jay philoon
Nov 24, 2005 03:34 PM
