Weird Idle/Die Out in Neutral
Old Feb 11, 2013 | 12:20 PM
97black850's Avatar
Default Weird Idle/Die Out in Neutral
Hello,
I have a 1997 Base model 850 Sedan. It has 261xxx miles on it. I have just replaced the fuel filter, air filter, spark plugs, and distributor cap and rotor. After doing this the car would start right up, but it would take longer than usual for the RPMs to stabilize. They would dip way down and almost shut off. My car also does this if I put it in neutral above 30MPH, roughly. It is an automatic transmission with no engine mods. Any help or suggestions is greatly appreciated, thanks.
Old Feb 11, 2013 | 12:48 PM
Sounds like you have a vac problem. Did you knock something loose?
Old Feb 11, 2013 | 07:53 PM
97black850's Avatar
I will check that ASAP. We had to remove one of the vacuum lines when we took the air filter box out. I hope that is all it is, thanks
Old Feb 11, 2013 | 08:24 PM
97black850's Avatar
All the lines seem attached well.
SkyVolvo
Nov 6, 2023 09:52 PM
swiftjustice44
Oct 25, 2012 06:32 AM
sleepdotcom
May 30, 2012 11:07 AM
dman777
Dec 19, 2011 11:31 AM
