What is proper Crankcase Pressure?
Old Sep 5, 2023 | 03:19 PM
rsmigel's Avatar
Default What is proper Crankcase Pressure?
1994 Turbo 850 wagon, 201K miles averaging 5K miles per year. PVC system replaced 40K miles ago. Oil changed every 5K miles using Mobil-1 synthetic with prior “Motor Flush."
Just paid for new rear mail seal and now see leaking oil out of passenger cam seals, maybe quarter teaspoon when parked overnight. No engine codes, no oil burning, car runs well.
I remove the oil cap and attach a 5mm latex glove over the opening. At idle there’s not enough pressure to inflate the fingers; raising the throttle will slightly inflate the fingers then the fingers fall upon return to idle.
Does a properly running engine with good PVC system show a little positive crankcase pressure like mine?
I’ve got a $20 bottle of Bernie’s AT-205 ready to go into the crankcase…
Old Sep 5, 2023 | 04:38 PM
tonyfr's Avatar
It will inflate the glove if the PCV is bad.
Old Sep 5, 2023 | 05:11 PM
rsmigel's Avatar
So the crankcase should generally be under negative (slight vacuum) pressure?
Old Sep 5, 2023 | 06:23 PM
tonyfr's Avatar
Correct.
https://www.youtube.com/shorts/FOxfvzEFpYg
Old Sep 5, 2023 | 08:25 PM
rsmigel's Avatar
Perfect! Thx for the quick reply!
Old Sep 6, 2023 | 03:02 PM
firebirdparts's Avatar
If you look at where the crankcase is vented to on a turbo, it's never going to see any significant vacuum. The intake does see pressure drop from the air filter, so there is a tiny tiny bit of suction applied. If the engine is absolutely perfect, you could get the pressure down to zero. Not easy, though.
Old Sep 9, 2023 | 08:20 AM
rsmigel's Avatar
The previous video shows negative pressure (vacuum.). Will an older engine with a new PCV system show negative pressure?
Old Sep 9, 2023 | 12:38 PM
tonyfr's Avatar
Both of my 850R's do.
Old Sep 13, 2023 | 09:39 AM
rsmigel's Avatar
OK, looks like I need to replace the PCV... again.
I see three options, IPD aftermarket @ $111 which includes (3) hoses and the oil trap, FCP Euro (OEM) @ $387 which includes (6) hoses and the oil trap, RockAuto (URO) @ $84 which includes (3) hoses and the oil trap.
Will the (3) hose option be sufficient?
Nikolalujce
Dec 8, 2014 01:26 PM
Goody61865
Dec 8, 2014 11:43 AM
Goody61865
Dec 5, 2014 09:24 AM
Nikolalujce
Sep 12, 2014 07:18 PM
Psaboic
Nov 11, 2006 02:07 PM
