what to replace
Old Apr 7, 2006 | 02:20 PM
KINGI5T850's Avatar
Default what to replace
what should i replace when i change a timing belt ? and on the car it sad to use a speical kind of coolent what should i use?? and how many valves go bad when the timing belt goes?
Old Apr 8, 2006 | 12:56 PM
skyman's Avatar
Default RE: what to replace
Depending on how many miles are on the car and whether the belt has ever been changed, I miight consider replaciing the tensioner as well as the water pump while it was apart.
Old Apr 8, 2006 | 03:38 PM
No special coolant needed.
I would do the tensioner pulley and idler pulley.
Did you break a belt?
If so most likely most of the intake Valves are bent.
Old Apr 8, 2006 | 05:56 PM
rp850's Avatar
You might want to change the cam seals if they are leaking. I'd pick up a serp belt too since you're going to have to take it off anyway.
momsvolvo
May 11, 2009 12:02 PM
halekai
Jan 18, 2008 08:59 AM
randyjoy
Nov 7, 2004 08:23 PM
jamestolson
Jun 10, 2004 12:23 PM
Pandrew
Oct 10, 2003 09:35 PM
