What size are vac lines to wastegate & wastegate actuator?
RE: What size are vac lines to wastegate & wastegate actuator?
I believe they are6mm rubber vac lines.What i did just to make sure was go into advanced auto (or other) andtook the piece between my intake piping and the Boost controller solenoid located on the side of your intake box for the correct size. I decided to do this because i noticed somewhat of some lag and the dry cracked problem as you have noticed also.I replaced all three lines (one from intake manifold to wastegate, 2-from turbo to controller, 3-from controller to intake) and all pressures are very nice now Hopethe best in your results!
