Whats in a tune up?
Old Aug 8, 2006 | 05:17 AM
ciao-rich's Avatar
Default Whats in a tune up?
Morning all! (morning in the UK)
I've seen on here that people have taken their cars to mechanics / dealers, and have had "tune-up" work carried out. Now in the days of carburettors and such, one could actually adjust the fuelling for the engine if they had gone waywood. But what can a mech do for our fully electronic fuel systems on the 850 besides replace rotor arms and leads and sparkplugs and decokes?
I didnt think there was much scope for tweaking fuel settings and timings.
Your thoughts?
Rich
Old Aug 8, 2006 | 01:46 PM
robert213's Avatar
Default RE: Whats in a tune up?
When most people think of tune-up, it includes things like...
Spark Plugs
Spark Plug Wires
Distributor Cap and Rotor
Some folks add to the list...
Air Filter
Fuel Filter
Ignition Coil
Timing Belt, including tensioner and water pump
Serpentine Belt
Some folks add even more...
O2 Sensors
Send injectors out to be professionally cleaned (http://www.rceng.com)
Fuel Pump
Vacuum Hoses
Intercooler Hoses
Clean Intercooler and Pipes
And I'll add even more...
Radiator and Heater Hoses
Wahler 87C/190F Thermostat
Replace Radiator Fluid
Magnetic Oil Drain Plug
Replace ATF
Hang a magnet in Power Steering Reservior to catch floating debris
Inspect Suspension and Engine Mounts
r213faq
Genuine Volvo Service - 850 series 1995-1997
Every 10,000 miles:
Oil Filter & Engine Oil: Replace
Battery Test: Check Electrolyte Level and Clamps
Brake Pads: Check Wear
-- In my experience, OEM Brake Pads must be replaced every 25K miles
Automatic Transmission: Check Shift Control; Check Fluid Level
-- In my experience, ATF must be changed every two years
-- Note 1998 Model Years and older use DEXRON-III
-- Note 1999 Model Years and newer use Mobil/Volvo JWS 3309.
---- It is not synthetic. It is expensive at $18/quart.
Fluid Levels: Check/Adjust (Coolant, brake fluid, power steering and washer)
-- Note Our power steering system uses DEXRON-III, not generic PS fluid
Diagnostic Codes: Check, Reset
Tires: Check for damage and wear (Rotate at customer's request)
Lubricate: Hood Hinges, Door Hinges, Door Striker Plates,
Clean: Power Antenna
Reset: Service Light
Every 20,000 miles:
Brake Hoses: Check
Fuel Lines: Check
Steering, Front & Rear Suspension: Check
Drive Shaft Joints: Check for wear/play
Lubricate Belt Tensioner Pivot Bearing
-- I would guess this means both Serpentine and Timing
Every 30,000 miles:
Air Filter Cartridge: Replace
Spark Plugs: Replace
Brake Fluid: Replace at interval or every two years
Every 60,000 miles:
Drive (Serpentine) Belts: Replace
PCV: Replace Flame Guard, Clean Nipple and Hoses
Every 70,000 miles:
Timing Belt: Replace
Every 100,000 miles:
EGR System: Check and Clean
Fuel Filter: Replace
In my opinion, Here is a list of items that have been omitted...
1) ATF: Replace
2) Coolant: Replace
3) Thermostat/Engine Coolant Temp (ECT): Replace
4) Water Pump: Replace
5) O2 Sensor: Replace
6) Ignitor Module: Replace
7) Struts/Spring Seats: Replace
Old Aug 8, 2006 | 01:50 PM
robert213's Avatar
ORIGINAL: ciao-rich
Now in the days of carburettors and such, one could actually adjust the fuelling for the engine if they had gone waywood. But what can a mech do for our fully electronic fuel systems on the 850...
You are correct, an engine management computer controls the air fuel mixture. But, it also controls one other thing -- ignition timing.
Both of these functions can be re-programmed by companies such as http://www.ipdusa.com and http://www.rica.nl
southernoregondefense
Jun 29, 2011 05:45 PM
r2u
Aug 21, 2008 10:25 AM
isons2004
Aug 4, 2005 09:03 PM
DI740
Apr 21, 2005 11:51 PM
graphite740
Jul 18, 2004 06:03 AM
