Whats wrong with my car???
Old Nov 29, 2016 | 03:33 AM
Chrisg13's Avatar
Default Whats wrong with my car???
I just changed my Pcv system on my 97 850 T-5 and added a intake manifold spacer and when I put the car together this happens when I try to turn on the car, any ideas on what I did wrong?
Old Nov 29, 2016 | 07:05 AM
firebirdparts's Avatar
Could be a big vacuum leak.
Old Nov 29, 2016 | 07:13 AM
tryingbe's Avatar
Torn hose, loose hose clamps, etc.
Old Nov 29, 2016 | 08:16 AM
Psaboic's Avatar
Check to make sure the manifold is properly tightened down. I had a torn manifold gasket that caused a simlar issue. ALso check to make sure you are getting a good supply of fuel.
Old Nov 29, 2016 | 12:34 PM
Chrisg13's Avatar
How do I check to see if it has a good fuel supply?
Old Nov 29, 2016 | 10:21 PM
Psaboic's Avatar
One way is to take the end cap off the fuel rail and see if you have good fuel pressure. Press in on the end of the valve (looks like a tire air stem valve) and you should get a good squirt of fuel when you press in on it if there is ample pressure.
Old Nov 30, 2016 | 06:20 PM
M5+B7+S63&theVolvo's Avatar
https://youtu.be/VSH5TQPvEys
Did you reconnect your mass flow sensor?
PhantomTEG
Oct 19, 2010 04:04 PM
big alan
Mar 15, 2010 02:21 AM
danadornburgh
Feb 20, 2009 09:23 PM
alsawye
Dec 16, 2008 05:00 PM
T5RACER
Nov 3, 2006 04:57 AM
