where is the flame trap???(with pics)help!
Old Jun 23, 2008 | 08:36 AM
chef's Avatar
Default where is the flame trap???(with pics)help!
Hi guys, i just wanted to know where the flame trap is located on my 95 850 (non-turbo), what can i use to clean it up? is carb cleaner okay?
i took some pics of the throttle body area, can you guys tell me or highlight the pic in which the flame trap is located thanks
fabs..
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Image 7
please let me know if you see it in the pics...thanks
fabs
Old Jun 25, 2008 | 12:22 AM
TacklaNHL's Avatar
Default RE: where is the flame trap???(with pics)help!
Looks like you've got it in Image 3 - and on Image 4 you can just BARELY see it - your finger is pointing at it, or touching it.
In the first two pictures there's a tube - that tube runs to the throttle body. Take the throttle body out and you'll find it. In image 6 you're pointing to a vacuum hose - which is VERY brittle, be careful when handling. That vacuum tube runs to the vacuum tree - which is EASY to break but only a few bucks if you do - that sits on top of the throttle body. The vacuum tubes pull away from the vacuum tree - they just slide on and off - you might want to use some WD-40 or something to loosen it up before you go pulling on the vacuum tubes - again, it's all very brittle and you'll want to be delicate there.
Take the throttle body apart, clean it out while you're there as this should be regular maintenance that you do a couple times a year. You'll clean a bunch of gunk out of it if you've never done this before and it'll help your car's idle A TON!
The flame trap looks like a concave-bowl-type thing with a bunch of holes in it. Might be better just to replace it when you get to it. It tends to get gunked up and tough to get completely clean. FCPGroton.com sells them for just a few bucks. Oh and by the way, the plastic ones are supposedly better than the metal ones - you would think the opposite but i've read places that people highly suggest the plastic one. Not sure if FCPGroton sells both (I know for a fact they sell the plastic ones) - but just so you know.
Here's a step-by-step with photos:
http://volvospeed.com/Repair/ftrap.php
boarders123
Jun 23, 2012 09:16 PM
r.e.wing_fc3s
Jan 31, 2010 03:51 PM
propbuster
Mar 8, 2009 11:43 AM
netconcepts
Aug 25, 2005 09:28 PM
djbaines
Dec 16, 2004 12:22 PM
