white smoke
Old Jan 27, 2008 | 02:39 AM
rjmombo's Avatar
Default white smoke
I have an 850T 94' wagon. Dealership can't help me can you? White smoke billows out tailpipe after initial running ,then rest and then the smoke,w/ aweird smell. 1500.00 later still smokes? Help! rjmombo
Old Jan 27, 2008 | 03:26 AM
info2x's Avatar
Default RE: white smoke
Low on coolant?
[align=left] [/align]
Old Jan 27, 2008 | 06:35 AM
JPN's Avatar
JPN
You're sure the smoke is white and does not have a hint of blue?
And see if can smell fuel in the reservoir. Open the cap when the engine is stone cold and smell for fuel/look for a hint of fuel in there, that is, if the coolant is still visible as info2x has noted.
The best thing to do is either to have the cooling system pressure-tested or have the engine compression-tested.
Let us know your findings first.
JPN
Old Jan 27, 2008 | 09:21 AM
What did they just do to the car?
Is the vent system plugged?
Old Jan 27, 2008 | 10:10 AM
Psaboic's Avatar
Sounds like coolant or excess fuel burning. Based on the reported weird smell I'm leaning toward coolant. I would do as JPN suggested, pressure test teh cooling system first, and if that turns up ok, do a compression check on the engine. Might be a leaky head gasket
Old Jan 27, 2008 | 11:57 PM
850GLTWAGON's Avatar
do a leak down test asap
Old Jan 28, 2008 | 05:51 PM
I have seen alot of cars lately with clogged vent systems making the car smoke like a train.
Pv12345
Oct 11, 2007 08:33 AM
V8SRSLO
May 9, 2007 05:57 AM
justben714
Jan 27, 2007 11:02 AM
jay philoon
Nov 6, 2005 03:41 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
