Bluetooth for playing music from phone
Old May 19, 2024 | 10:23 AM
Charlie911pilot's Avatar
Default Bluetooth for playing music from phone
New to the forum and recent owner of 2011 C30 T5 R- Design - has factory connectivity with phone to transmit and receive calls only; not able to play music from phone; is there a work around? How do I enable music playing AND still retain the factory ability to make calls?
Old May 28, 2024 | 03:48 PM
homer 6969's Avatar
Got a Gizmo for phone to radio bluetooth broadcast to fm works fine,,, Plugs into rear seat outlet. cheap fix.bluetooth adapter on amazon.
Old Jun 26, 2024 | 03:25 AM
paulfarrell's Avatar
This works well. https://www.tindie.com/products/just...-c30-c70-xc90/
Old Jun 26, 2024 | 09:01 AM
I found something much less complicated and more effective. It still allows the installed hands free phones bluetooth to work as advertised but now I can play music through my Android/iPhone simply by plugging this into the 3.5mm port located in the arm rest cubby. it can remain stand alone plugged in and require charging as needed; but if you connect the supplied USB-A cable to this device and have it plugged into the USB-A port in the same cubby, you have everything you need. Please be aware there no apps that come with this. You control there music directly from your phone. It only cost $16.00. Heres the link to this bluetooth device. Enjoy!!
Amazon Amazon
Old Jun 26, 2024 | 09:03 AM
Old Jun 26, 2024 | 09:25 AM
https://www.amazon.com/dp/B086YVCPJ8...t_details&th=1
Not all Volvos have the auxiliary jack socket. Mine hasn’t.
Old Jun 26, 2024 | 07:38 PM
too bad. maybe its on the T5 Premier package
Old Jun 27, 2024 | 01:07 PM
check out Crutchfields to see what they have - Grom made adaptors that used the CD-changer port to support phones etc. 2011 was back when the base units only used bluetooth for phone commands.
Old Oct 21, 2025 | 10:15 AM
hkhctslue's Avatar
Good discussion about the Bluetooth music issue in the Volvo C30. If your phone pairs but no audio comes through, try switching the car stereo’s source manually — some older models need you to select “BT Audio” or “Media” each time. Firmware updates or aftermarket adapters can also fix it. I’ve had similar setup frustrations, and using intermittent fasting app https://wellness-app.com/ actually helped me stay patient and take breaks instead of getting annoyed during troubleshooting.
Thanks for information!
Old Dec 29, 2025 | 11:10 AM
norfolkrobz1000's Avatar
use the bluetooth adaptor,fits in back of stereo,works excellent..
joseph guindy
May 27, 2024 10:05 AM
ANewUsedVolvo
Aug 24, 2022 01:27 PM
djkidd
Jun 10, 2021 01:29 AM
spektors
Volvo C30
Aug 19, 2017 07:20 AM
trochefort
Aug 2, 2009 04:38 PM
