Do C30 engines use oil
Old Nov 20, 2013 | 09:41 AM
jg1's Avatar
jg1
Default Do C30 engines use oil
Just curious, I have an S70 which has always used a little bit of oil from day one. Wondering if the C30 engine suffers from the same issue? I am looking at buying a 2009 C30; thanks.
Old Nov 20, 2013 | 02:27 PM
ES6T's Avatar
All engines will use some amount of oil
Old Dec 10, 2013 | 12:53 PM
dreampod5's Avatar
hmmmm...my C30 doesnt use a drop of oil.
Old Dec 10, 2013 | 01:30 PM
ES6T's Avatar
Yes it does. It may not be significant but it does.
Old Dec 10, 2013 | 01:58 PM
dreampod5's Avatar
ok. lets agree to disagree here.
Old Dec 10, 2013 | 03:50 PM
ES6T's Avatar
Any internal combustion engine will use some amount of oil. Volvo actually has a spec for it somewhere.
Old Dec 10, 2013 | 08:26 PM
dreampod5's Avatar
yep...when a customer has excessive oil consumption like on the v-8 and the new inline 6's..we replaced the piston rings..and the engine seals and the head. and yes..i agree the older engines that used conventional oil do "use" some amount. the newer engines that use synthetic oils are built with a closer tolerance and don't "use" oil. when i got my 2008 C30 6 months ago with 73k miles on it the first oil change i did i measured to see if my engined used any oil because of the turbo. and guess what...7 quarts out...7 quarts in. no oil loss whatsoever. And yes..i worked at Volvo for 7 years. and i am not aware of any spec volvo has for engine oil usage. However..i am not going to get into a huge pissing match about oil. the T-5's are great engines with almost zero issues. I have said my peace and will leave it at that.
Old Dec 11, 2013 | 08:33 AM
ES6T's Avatar
Oh yeah, not anywhere near as bad as the I6s, where its actually a problem.
08 doesn't use synthetic.
And you overfilled your oil.
The spec is .35-.55 liters per 1000 km.
boxpin
Jul 16, 2009 08:30 PM
STREETFIGHTER50
Apr 7, 2009 12:21 PM
ogotaj
Mar 22, 2008 02:57 AM
PANTYEATR
Jan 17, 2008 12:22 AM
KINGI5T850
Apr 4, 2006 11:45 PM
