DPF & Throttle Body Problems 1.6 D 2009
Old Dec 9, 2017 | 03:27 PM
The Gas Man 2's Avatar
Default DPF & Throttle Body Problems 1.6 D 2009
Hi, I'm trying to help my daughter with her C30 problems! Earlier in the year she miss-fuelled by a small amount, the garage advised her to brim the tank with diesel and all should be ok! A few weeks later 'limp mode' set in, another trusted garage cleared the codes and said the DPF & throttle body needed to be changed, but the car wasn't worth it! I find this hard to believe!
I'm pretty handy with the spanners, how hard is it to change the DPF & throttle body and what costs are likely to be involved?
Thank you for your help.
Old Dec 12, 2017 | 08:19 AM
Pavtastic's Avatar
Hi
I am not a specialist but also find it hard to believe.Try first removing throttle body and give it a good clean.
The below should help.
DFP filters are around £100-200
BM11006 | VOLVO C30 2.0 10/06-12/10 Diesel Particulate Filter | Buy Catalytic Converters Online
If you are good with spanners and have some spare time, i would suggest cleaning the throttle body first, also helps to clean mass airflow sensor
Cost mostly your time, plus £5 for kerosene and contact cleaner. Then i would consider replacing DPF or you can consider the below
https://www.halfordsautocentres.com/...dpf-deep-clean
Hope this helps.
86volvoguy
Apr 20, 2017 10:50 PM
treestone27
Apr 29, 2014 07:40 AM
nathaimu
Volvo C30
Nov 13, 2013 06:53 AM
AMAP58
Oct 29, 2013 07:03 AM
