Hiccup
Old Nov 15, 2022 | 10:20 AM
smcevoy123's Avatar
Default Hiccup
Good afternoon everyone,
I own a 2008 Volvo C30 that has the automatic transmission (if that makes a difference) that just ticked over the 70,000 mile mark. I was driving it earlier and realized that under acceleration it will seem to 'hiccup' (or stutter). I did not buy this car new, I am (I believe) the second or maybe the third owner and only got it about 5,000 miles ago, so I have no knowledge of any previous maintenance done to the car. What could be causing this issue? What would a possible good fix be? Also I don't know if it's related, or even a real issue, but the accelerator does seem to get more and more firm the further you get into it. Is this an issue at all?
Old Nov 15, 2022 | 10:22 AM
Dingus1's Avatar
Any Check engine light? I had a similar thing happen when an intake tube came off the throttlebody aka intake leak.
Old Nov 15, 2022 | 10:32 AM
smcevoy123's Avatar
No check engine light has come onto the dash. I also don't have a scan tool (probably should though).
Old Nov 15, 2022 | 11:10 AM
you can borrow a scan tool from a local Autozone etc. Hiccups under load often point to ignition issues - when were the plugs last changed? You may have an issue with one of the coil packs as well. When I had a similar issue (stumbles/no code), I drove the car fairly agressively on the highway to get it to produce a CEL and that told me which coil was suspect. PS - coils don't all go at once so save your money by not buying a set of 5 when its likely only one is bad. Plugs are typically due at 60K miles, plus you may have a fuel issue so for your next few tankfuls run a brand name 93 octane (ie Mobil, Shell, Texaco etc) as those brands have extra detergents. You can also throw a can of Techron fuel injector cleaner in the tank when doing your next fill as well.
Old Nov 15, 2022 | 11:31 AM
smcevoy123's Avatar
I'm not sure if the plug were ever changed. I haven't seen anything in the super limited records I saw.
Old Nov 15, 2022 | 02:03 PM
That's an easy place to start. You can replace the plugs (go with Genuine Volvo - they come pre-gapped and are the correct specs for you engine. You can buy online for a discount at a dealer web store) and do the premium gas thing and see if a CEL ever appears.
Old Nov 15, 2022 | 04:47 PM
smcevoy123's Avatar
Sounds good. Thank you so much. One last question, with my car just rolling over 70,000 miles, do you know any near future (within 10,000ish miles) maintenance items I need to be looking out for? 70,000 mile maintenance (if that's a thing)? Anything getting replaced?
ross0
Volvo C30
Dec 29, 2021 05:25 PM
S-Works
Volvo C30
May 28, 2020 01:02 PM
Francesco Walker
Volvo C30
Nov 5, 2017 05:53 AM
joel12
Volvo C30
Nov 7, 2014 01:24 PM
Ella
Jul 16, 2011 05:45 PM
