P0128
Old May 7, 2020 | 09:51 AM
Frank Schmidt's Avatar
Default P0128
I bought an 08 C30 R-Design in Jan and I keep popping code P0128. Coolant not reaching temp. Heat works fine but temp rarely exceeds the 1/3 mark. Runs about 150-160°. Should I replace the thermostat and sensor or does it hurt to run it cool? Thanks
Old May 7, 2020 | 12:43 PM
I'd simply replace both the ECT sensor and the thermostat. You probably need to pop the thermostat cover off to reach the senso so its a good time to do both. Since you don't know if you have a thermostat stuck open or a wonky sensor, I'd just spend the $75 and set the car right. I don' think there's a lot of risk driving for a short while but the fuel trim may be a bit off due to an incorrect temp signal. (I'd guess it'd run rich but can't say that for sure)
Old May 7, 2020 | 01:00 PM
thanks for the response. Didn't think about fuel trim. I'll just replace both
442john
May 14, 2016 10:32 AM
cheesenacho
Feb 29, 2012 09:32 PM
bgeacook
Aug 13, 2009 12:43 PM
