thermostat or temp sensor?
Old Aug 13, 2009 | 11:38 AM
bgeacook's Avatar
Default thermostat or temp sensor?
occasionally i'm getting a fault code stating the temp is below the t.stat temp (sorry cant remember the code #). the needle goes right to the middle of gauge (or ever so slightly less than middle- cooler).
is it more likely the t.stat is bad or just sensor mis-reading the temp?
thanks in advance
Old Aug 13, 2009 | 12:43 PM
Somthngfrce's Avatar
Hard to say, I would do both. FYI, most Volvo shops customarily change out the temp sensor when doing the thermostat and vice versa.... Pricewise too they are cheap (thermostat is 13 bucls and temp sensor is like 35ish thru fcp)....
cheesenacho
Feb 29, 2012 09:32 PM
Aryding
Dec 4, 2010 03:22 PM
nvs40
Dec 30, 2006 12:14 AM
dcox612
Apr 23, 2006 01:08 PM
