Worn Tyres Question: When Should I Replace Them?
Old Nov 22, 2024 | 05:35 PM
VinR1's Avatar
Default Worn Tyres Question: When Should I Replace Them?
Hi everyone,
I’ve noticed the tread on my tyres is getting quite low, and I’m wondering how to tell if it’s time to replace them. I know the legal minimum tread depth is usually 1.6mm, but is it safer to replace them earlier?
Also, does uneven wear mean something's wrong with alignment or suspension? I drive in a mix of wet and dry conditions, so safety is a big concern.
Any tips for choosing replacements, or advice on how to extend the life of tyres, would be greatly appreciated!
Old Nov 22, 2024 | 05:36 PM
VinR1's Avatar
Originally Posted by VinR1
Hi everyone,
Any tips for choosing replacements, or advice on how to extend the life of G Tyres, would be greatly appreciated!
Thanks in advance for any help
Old Dec 17, 2024 | 08:55 AM
richardkonrad's Avatar
simple if you drive in a lot of rain and wet conditions then the less thread you have then the tire will displace less water and its easier to skid , obviously new tires are best but we cant drive on new all the time so 1.6mm is quite safe at the legal speed of say 120km/hr but if you in Germany and want to drive at 250 then no
On the other scale if you live in a dry country where it does not rain then even 1mm is fine , here in South Africa the limit is 1mm , its fine in winter as there is no rain for months , but not summer as one has big downpours , lots of accidents in summer here when it rains and its not due to 1mm rule , some have almost none !
There are many reasons for uneven tire wear , tire pressure, bad suspension , alignment , unbalanced tires and obviously bad driving (spinning tires on pull off) and driving around fast bends fast on a regular basis
There have been no replies to this thread as its a general question and not related to Volvo, probably a google search will give these results
Spangtangler
Dec 7, 2016 03:39 PM
bubrockit
Jul 21, 2012 06:00 AM
daisy3d
Dec 7, 2008 08:51 PM
tr_car_nut
Aug 20, 2008 12:10 PM
Lawbrum319
Aug 8, 2007 01:25 AM
