01 Volvo C70 Engine Codes (((PLEASE HELP)))
Old Sep 9, 2010 | 03:02 AM
Ooh1See7evenT's Avatar
Exclamation 01 Volvo C70 Engine Codes (((PLEASE HELP)))
Hello there Fellow Volvo Enthusiast.
I am the owner of a 2001 C70 HT (hardtop) w/ a 2.3 t5 motor. I recently had the engine light come on, so I had my buddy scan it w/ his CAN OBD II Code Reader & it gave Me these codes back. 2 of which I am familiar with but would like some help with the 3rd, also info on how I can fix these issues...
Engine Codes Below
1.) p0013 Camshaft Position Actuator B-Bank 1 Circuit Malfunction [[[[ Was told 2 replace the Camshaft Position Sensor, which I have already spent $250+ and changed the C.P.S. Myself, But have yet to drive it and rescan it again since the code came on and i replaced it. Will be doing so after I figure out problem #2]]]] (listed below)
2.) p0303 Misfire Cylinder #3 Detected [[[[I will be changing the PLUGS tomorrow, also some other tricks &/or tips I have found on here.]]]] Any & All suggestions WELCOME!!! Hopefully that does the trick so I can drive it and rescan it once the ENGINE LIGHT COMES BACK ON for problem #3 (listed below)
3.) p1332 ????? The code which I am unable to define without going to the (((DEALERSHIP))) PLEASE HELP!!! Thank You for Your Time & Cooperation
-Ooh1See7evenT
2001 Volvo C70
Old Sep 9, 2010 | 03:40 AM
dale66vt's Avatar
Google search came up with several explanations for P1332.
http://www.matthewsvolvosite.com/for...=23675&start=0
http://www.matthewsvolvosite.com/for...hp?f=1&t=21162
ka3ax
Nov 20, 2013 07:42 PM
healthnt
Jul 6, 2010 12:07 PM
q2quest
May 23, 2009 06:35 PM
