Please help with Check Engine Light Codes....
Old May 22, 2009 | 03:34 PM
q2quest's Avatar
Default Please help with Check Engine Light Codes....
I have a check engine light on and I read the codes with a scanner. The scanner read P2180 and P2178: system too rich off idle bank one and two, P2192 and P2194: system too rich @ higher load bank one and two, P0103: Mass or volume air flow circuit high input. Does anyone have any ideas? Does this sound like a mass airflow sensor failure? Thanks
Old May 22, 2009 | 09:33 PM
Either a bad MAF or a big vacuum leak.
Old May 22, 2009 | 11:27 PM
q2quest's Avatar
If it were a big vacuum leak, wouldn't the car run pretty rough all the time? The car actually runs fine most of the time. I reset all the codes and the car drives normally for a while with no cel. But, upon start-up in the morning the idle can be somewhat erratic until it warms up.
Old May 22, 2009 | 11:36 PM
Not always sometimes it will only leak under boost.
The plastic pipes on the top of the motor are known to crack.
Old May 23, 2009 | 05:24 PM
q2quest's Avatar
Thanks, I'll give it a look.
Old May 23, 2009 | 06:35 PM
Alot of times one person has to be inside with it in gear and foot on the brake and press the gas till the motor goes into boost. Then feel around the piping for leaks.
xyz
Aug 27, 2016 11:28 AM
DonWin
Apr 16, 2015 10:35 PM
cmilehc16
Jan 4, 2013 11:37 AM
ckevg
Mar 19, 2010 08:45 PM
ROBLU540
Sep 11, 2008 06:37 PM
