2000 C70 2.4L,A/T(max 2000 rpm/obviously has no power)
Old Jul 29, 2013 | 09:51 PM
woodlief's Avatar
Default 2000 C70 2.4L,A/T(max 2000 rpm/obviously has no power)
Problem is mostly there all the time/sometimes problem is gone for a few minutes.Fuel pressure is good.No check engine light on.Scan tool does not reflect much throttle position change when pressing the accelerator pedal.
(suspect throttle plate not opening,because of other scan tool readings(not much change in air flow).
AllData(diy version is not very helpful).I would like to try measuring the signals at the accelerator pedal first,then at the throttle body with my Fluke 88 automotive test meter.
I am a retired master ASE certified technician and was very good with onboard computer diagnosis/repairs.I just cannot find any info on this problem yet.Guess will try to buy an OE manual,but am afraid that the diag procedures will be with using the Volvo proprietary equipment..
Old Jul 31, 2013 | 09:29 AM
Cactuslegs's Avatar
What about the ETS light, is that on? I think 99 to 2000 was the year they switched from cable throttles to drive-by-wire.
Old Jul 31, 2013 | 10:33 PM
woodlief's Avatar
Default no engine related warning lights on.
No engine related warning lights on.
VTs70GLT
Jan 14, 2014 09:58 AM
Alley-Oop
Apr 19, 2012 10:24 AM
tmsade06
Apr 27, 2010 10:35 PM
loup
Sep 10, 2006 08:20 PM
