2004 c70 engine mount question
Old Oct 17, 2014 | 07:47 AM
helix's Avatar
Default 2004 c70 engine mount question
about 6 months ago I bought a 04 C 70 that had some engine mount issues. The car was really bUzzy when I bought it but I replace the upper torque mount, the lower transmission mount, in the front engine mount (the one next to the right front wheel.) That seemed to fix the issue but it was never quite right now the upper torque mount needs to be replaced again after only six months of driving. Whatever I look online I keep seeing a rear hydraulic mount for sale. the problem is I don't see this mount in my car. There is a hydraulic mount in the front of the car right behind the intercooler. There is not one that I can see in the back of the engine all that is there is the turbo. Am I missing something? Did they make a C 70 without a rear engine mount?
Old Oct 17, 2014 | 09:01 AM
ES6T's Avatar
There's one back there
Old Oct 17, 2014 | 11:57 AM
helix's Avatar
Can someone.provide a pic.exactly were.it.is. i see schematics but a pic may help. I see a.spot over on the.drivers side on the back.were.it.looks as if there is on but its.over the steering u joint
Old Oct 17, 2014 | 12:32 PM
ES6T's Avatar
I don't have any pics, but it's the only big rubber mount back there.
Old Oct 17, 2014 | 05:53 PM
helix's Avatar
Then mine is mia. Im assuming there is a riser that goes around the steering rack?
Old Oct 20, 2014 | 12:43 PM
Cactuslegs's Avatar
The rear engine mount actually anchors to the power steering rack (unfortunately).
Old Oct 20, 2014 | 05:35 PM
helix's Avatar
so things are starting to make sense now because the last post I crawled underneath my car and found that rear mount as you can see the pad is not even touching the riser on the steering rack. Is this my problem?
Old Oct 28, 2023 | 08:46 AM
merlinx's Avatar
Old thread but did you ever get an answer on this? Im running into the same issue with a 2004 c70 2,4 t
Chappy
Dec 17, 2014 08:50 AM
Bikeartatx
Apr 20, 2014 08:29 PM
burakuysal
Nov 24, 2013 05:52 PM
tuner4life
Apr 27, 2012 06:41 PM
isa91
Dec 29, 2008 11:14 PM
