2004 c70 t5 gt convertible starter clicks?
Old Apr 25, 2013 | 02:49 PM
Millsy's Avatar
Default 2004 c70 t5 gt convertible starter clicks?
Hi welcome all,
I just purchased a c70 t5 gt convertible with 42k on the clock.
I brought it off my dads friend which has been sitting in his garage for the past 3yrs. I've had the car 3 weeks an always started till the other day, an it now clicks when it goes to start I've had new starter new battery checked the relay and the 50a fuse all look fine even started it after takin relay cap off.
So didn't start mon went to it yest fired straight up. Went to it today clicked again 15times then started used it for 3hrs with starting several times? Can't be to much. Can any of you people help me at all?
Also plugged it into obd11 no codes at all?..
Regards
Old Apr 26, 2013 | 04:23 AM
MSGTUSMC's Avatar
My 1998 C70 coupe did the same. Check all wire connections to ensure all are tight & signs of arching. I had to replace the ignition switch. Most auto parts stores will check complete starting system for free!
hemismith
Mar 15, 2015 01:52 AM
liweih21
Oct 3, 2013 08:41 AM
ben322
Apr 16, 2013 07:04 PM
designernz
Mar 24, 2013 06:32 PM
dpallen
May 18, 2009 03:40 PM
