2006 C70 rear coil spring replacement
Old Apr 3, 2021 | 08:24 AM
belairbarca's Avatar
Default 2006 C70 rear coil spring replacement
I need to replace the rear coil springs on my 2006 C70. Couldn't find any DIY videos or threads. Would appreciate some steps, a video or a thread that discusses the process. I'm not interested in lowering, just want to replace since the tires are hitting the insides wheel well. I've already replace the shocks, which worked to an extent, but still getting some bottoming out, and that's without any additional weight in the trunk. Thanks in advance.
Old Apr 3, 2021 | 06:45 PM
Nidantwo's Avatar
for next time (future reference).. suggest that you get fully load struts, which includes the springs and is easier to install.
Old Apr 3, 2021 | 07:02 PM
I don't believe that's possible on a 2006 C70 rear suspension.
Old Apr 4, 2021 | 07:42 AM
Seems like this V50 video should work:
This Ford Focus based on the P1 frame may also be helpful for lowering and raising the control arm:
2000VolvoS40T
Oct 22, 2015 05:09 PM
mark.hollinshead@googlemail.com
Feb 19, 2013 07:57 AM
cb1313
May 7, 2010 01:57 PM
cb1313
Mar 1, 2010 10:45 AM
biteydog
Sep 14, 2009 06:42 PM
