2007 Volvo C70 T5 Hardtop convertible issues
Old Jul 12, 2020 | 09:21 AM
Teanna Holloway's Avatar
Default 2007 Volvo C70 T5 Hardtop convertible issues
I have a 2007 C70 that I had purchased in March...I have had numerous issues since I bought it...I should mention it is 2020 so it's 13 yrs old with only 102,000 miles...I have had to replace fuel sensor switch, silver coil for the air, the front axel, and now my top will not go down. I watched a video on YouTube in order to manually lower the top into the closed position and after I had closed it and locked it in place using alen wrench it began to make an incredibly annoying dinging sound after going over 2miles an HR. So I began pulling fuses but for some reason it always ended up shutting air and radio off. Finally found the fuse to shut off that alarm and no longer displays the warning on dash. It is the fuse for headlight washers retractable hardtop and compartment locks..holy crap it worked!!!!! 20amp fuse under hood refer to your manual fuse location..
Old Jul 17, 2020 | 07:20 PM
Tony Molina's Avatar
hi.. how did u manually lower it?
Old Jul 18, 2020 | 12:07 AM
Default Manual top operation
I had to YouTube a video..https://youtu.be/i6NVwfXUi5s...this is the link but if it doesn't work I searched in YouTube Volvo c70 manual top operation
Old Jul 8, 2024 | 02:26 PM
traciusvi's Avatar
Default I have the same problem!!
Having the same problems. I got the truck to close back. I followed the instructions from the video. Now I’m going to look for the fuse so it can stop that horrible noise!!
Old Sep 5, 2024 | 07:07 PM
tedders's Avatar
Default What's happened since?
Hi,
did you get the top fixed? What was the problem?
Thanks!
Drive laughing!
Tedders
DWR
Jan 14, 2017 11:41 AM
woof
Oct 20, 2013 09:16 AM
C70XC90
Nov 21, 2011 10:39 AM
Hownice
Jun 5, 2010 08:34 AM
OliverQi
Aug 17, 2007 12:25 PM
