2011 volvo c70 front passenger power window
Old Apr 20, 2023 | 11:22 AM
Jenpark's Avatar
Default 2011 volvo c70 front passenger power window
The front passenger suddenly refused to close. The window will lift about 3-4 inches & stop. The window switch/motor will move the window to entirely open but will not close. I checked the fuse (82). It is fine. If I move the outside mirror to either extreme left or right position, the window will not move at all. I return the outside mirror to normal driving position & the window raises 3+ inches. Please Help. The window replacement shop is no help.
Old Apr 21, 2023 | 09:46 AM
PixelDust's Avatar
It's likely that the window track is dirty, or there is an obstruction interfering with window when going downward on the track.
Spray Compressed air with a blow gun, and/or hot soapy water along the whole lower window area. It should take care of it.
It may take a while if you only have access to hot soapy water, but be patient it will work. Also, if you're confident enough, remove the black window scraper with a soft, but hard item: like a credit card, and it will make this job easier.
Good luck! Updates please.
William Frey
Jan 19, 2019 09:20 PM
patsvolvo2001
2001-2013 model year V70
Aug 9, 2012 10:39 PM
Dingley00
Feb 19, 2011 06:26 PM
warthog77
Jun 21, 2008 05:49 PM
